Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews
BeCM surgery and repair
The technical forum for the P38a/second generation Range Rover 1995-2002
Moderators: Tim (Scotland), Ka177ran, paul.adshead
Postby skippy3k » Wed Jan 12, 2005 6:45 pm
Since the day I bought my 95 RR 4.0, I've gotten Fuse Errors on fuses 2, 13, and 20 each time I turn on or off the Rover. The fuses checked out fine, as did all the different functions they controlled with the exception of the heated seats, which, when activated, always resulted in an additional "Fuse 2 Error" on the display. So I never gave it much concern, until the truth came out from my wife that she didn't "trust" riding in the Rover because of those errors! Well, I was shocked, and decided to make it my highest priority.
I dismantled engine compartment fusebox, and although it will need to be replaced at some point, I did not think it was the problem. I checked all the ground cables, fine. All circuits and wiring worked fine. All fuses under the passenger seat checked out OK. I spent many hours pouring over the ETM, trying this and trying that. Until I came to the conclusion that the problem must be within the dreaded BeCM.
After reading John's excellent page on "Demystifying the BeCM" and Andy's BeCM article, I decided to suit up for surgery. To add a little to John's write-up, the Torx wrench sizes he mentions are size 50 for removing the seat, and a tiny size 10 for removing the BeCM cover screws. Once the cover was off, I could immediately see where someone had spilled some coffee or something on one of the connectors and somehow it leaked onto the top power board, causing damage. (I would love to meet the brainiac Land Rover engineer who came up with the idea of putting the BeCM directly below the passenger seat and the lousy cupholders.)
I gave the board to my father-in-law, who owns a scale repair business. He agreed with John's analysis that most of the components on the top power board are fairly basic. After testing it, he found 7 "open traces" (?) and a bad relay. (I might have the terminology wrong here, someone please correct me if I do. Basically, 7 different circuits on the board weren't working correctly.)
He fixed the bad circuits with seven tiny little wires and a new relay, I put the BeCM back in the Rover, and wouldn't you know it....everything worked. I couldn't believe it. Even my heated seats. No more fuse errors.
What does this mean? I don't think it means that everyone can tear into their BeCM at the first sign of trouble. But I do think it shows that the BeCM can be repaired, if you are willing to take a chance and if it's in the hands of someone who is familiar with electronics. Although my problems weren't show stoppers, it did save me about $1000 or so for a replacement unit. My thanks to John and Andy for giving me the courage to do something so rash and foolish.
1995 Classic LWB
2000 DII
skippy3k
Solihull Member
great news!
Postby Jim-00-4.6 » Wed Jan 12, 2005 7:41 pm
Skippy:
That's some excellent news!! (your terminology was fine)
I also read John's article about the BeCM, and was encouraged to find that it isn't quite as scary in there as I had initially thought. And a little dissappointed that it wasn't more "hi-tech"; which is stupid, because then none of us could do anything in there!!
It sounds like lots of analog circuits, at least at the power end of things, so that means adding and changing is still reasonable for the DIYers like us.
This makes me wonder if the other ECUs are similar...
jim
Jim
2000 NAS HSE
Jim-00-4.6
Lifetime Contributor
Postby ranger4 » Wed Jan 12, 2005 10:39 pm
THanks guys this is great additional info -- i have now added the torx sizes etc to the page.
Keep up the great work!
John
John Brabyn
http://rangerovers.net
jabrabyn@rangerovers.net
First RR: 1989 Chamonix White Classic
Second RR: 1995 Epson Green 4.0SE
Present RR: 2004 Maya Gold Range Rover
User avatar
ranger4
Site Admin
BeCM trouble
Postby Ufodike » Fri Jun 23, 2006 1:19 pm
John has indeed been very helpful in a lot of tips from his site. I've found them handy from when I got my '91 Classic in 2001. I solved my power seat control switch problem with just a can of carburator cleaner. Ingenious! Several other problems were solved almost cost free from his contributions.
I added a '96 4.0 SE to my 'fleet' in 2004. I've not been able to drive the vehicle for 3 months now, bcos the security locked me out. I've tried inputting the code without luck. I've installed a brand new door latch from AtlanticBritish, yet the vehicle doesn't seem to be recieving the code (the side lamps don't flash). I'm sure I'm doing all thing right.
Suddenly, a techie from the dealership here tells me I have to get a new BeCM! This is where my headache begins.
I'm happy to hear I can toy around with the BeCM. Afterall, what have I got to loose?
John's detailed writeup on it makes it so easy to follow and understand. I'm not so much of an electrical/electronics person, but I'll give it a try.
I wish I had a father-in-law just like skippy3k :wink:
I really have to get this BeCM fixed, and save myself the huge cost of a replacement.
I love my 4.0 and would love to have it back on the road!
Help me somebody!!!
Ufodike
Postby skippy3k » Fri Jun 23, 2006 2:36 pm
I was going offer the option of sending me the BeCM, and I'll see what I could do to repair it. But I think your issue might be related to the logic part of the boards, which is an area my father-in-law and myself have not gotten into. Even if you replace it with another BeCM, you'll have to get it programmed for security.
One day I might pull a Shupack and master the previously un-masterable.
Scott
1995 Classic LWB
2000 DII
skippy3k
Solihull Member
Postby shupack » Sun Jun 25, 2006 5:03 pm
skippy3k wrote:...One day I might pull a Shupack and master the previously un-masterable.
Scott
Now I'm a verb??? That's awesome!
-Dennis
'95 4.0 "Darcy"
www.rover-renovations.com/
"As a tale, so is life; not how long
it is, but how good it is, is what matters."
-Seneca (4? B.C.-65 A.D.)
User avatar
shupack
Vendor
Re: BeCM surgery and repair
Postby p38arover » Sun Jun 25, 2006 8:06 pm
skippy3k wrote:. After testing it, he found 7 "open traces" (?) and a bad relay. (I might have the terminology wrong here, someone please correct me if I do. Basically, 7 different circuits on the board weren't working correctly.)
The terminology is correct. The traces are the tracks on the board. "Open" means "open circuit" i.e., the circuit is broken.
Ron (an electronics tech by trade)
Ron Beckett
1995 Range Rover HSE 4.6 V8 auto
2007 Yamaha XJR1300
2006 Suzuki DL650 V-Strom
RIP Bucko (1979-2007) Riding on forever
User avatar
p38arover
Deputy Admin
Postby Ufodike » Tue Jul 18, 2006 2:01 pm
Yehawww! :D
My 4.0 finally came back to life yesterday. I just mounted the reset BECM, and fired the engine up, and yes! It answered. Am I relieved? Drove it around today, and felt very pround, and had that superiour roving spirit return to me. :)
I found a UK based company called Avilec at: http://www.carelect.demon.co.uk
took out the BECM from my truck, opened it out of curiosity (not that I knew what I was gonna do to the inside), and finally sent it to Avilec, and for £300, they unlocked it, reset the EKA etc, and sent it back to me.
From there, it was just plug and play.
Thanks you all for all the info. It's was quite helpful. At least it gave me the confidence of knowledge that the problem was surely from the BECM, and assured my guts of taking it out of the truck.
Ufodike
Postby skippy3k » Tue Jul 18, 2006 2:31 pm
It's nice to know that company is back in operation. I heard a rumor awhile back that the guy who knew how to repair BeCMs there got sick or something, and was out for awhile.
Scott
1995 Classic LWB
2000 DII
skippy3k
Solihull Member
Postby howard » Wed Jul 19, 2006 5:58 am
I was told he'd retired and no-one else there knew how to do them, when I was first searching. I found another company, BBA Reman who also do BECM repairs. They might be UK only, I am not sure but they are on the net. Mine turned out not to be the BECM, but the company were very helpful when I phoned.
Howard
howard
Postby rangenam » Fri May 14, 2010 6:12 am
Hi from Namibia.
I have a few electrical gremlins in my '96 RR RL window only goes down, Rear window wiper does not work and few other small things..
After reading John page on the BECM I would really like to tackle this issue of Electronic gremlins with contact cleaner and see if it works then. I first have to wait for my RR to be returned to me after a new ABS and Modulator is being replaced, my question is:
If something is wrong and i have to take it to someone for repairs, what type person / business do i have to look for to repair ???
I am in Namibia so please keep in mind, 3rd World.
Chow rangenam
1996 Range Rover 4.6HSE, Coil Conversion, Custom Bullbar
1959 Mercedes 220s
1958 Chevrolet Apache, 5L V8 Vortec, 1997 Chevrolet K1500 chassis, still in restoration
1957 Chevrolet 3100 Original
1943 FORD CMP 4x4 needs to be restored
User avatar
rangenam
Postby sardolik » Thu May 20, 2010 3:20 pm
Hello everybody!
I've got 95 Range Rover 4.0 SE. It had couple problems but I'd handled it except message "RH window not set". The thing is that nothing of electrical stuff on that door doesn't work at all or at least properly. Window doesn't work at all, door lock works only manually, if lock the door it looks all doors and it also unlocks all doors, but it doesn't work with remote; mirror doesn't work at all too. Dealer is saying that I need new BeCM for about $1700.
What's your advice?
Appreciate your answers!
sardolik
Postby John W » Thu May 20, 2010 10:33 pm
sardolik wrote:Hello everybody!
What's your advice?
Doubtful you need a new BECM.Need to check the window/mirror switches .Mirror and window may have defective motors etc.
Key remote may be faulty,need new batteries or need to be resynced to your vehicle.
There is an anbundance of information on this site to help you with these issues.Have a good read. :think:
John W
1995 4.6hse
Enjoy it!!
John W
Postby jchabol » Fri Jun 25, 2010 10:22 am
You are right, John. I have had some of the symptoms described and they are due to the FOB not working, etc.
However, I now have a problem with the BeCM and the car won't start. It all started with a carpet cleaning service, after that the iPack was behaving erratically and after opening the BeCM to inspect water was found in. Now the car won't crank. I have purchased an unlocked BeCM but I have no means of programming it where I am. (no dealers around for miles and miles). The question is that I've got a newer BecM than my original 97 MY. Are the BeCM boxes essentially the same inside or do they change? I read somewhere in the forums that most times the damage in the BeCM is in the power board and the logic board remains ok. If I swap power boards the problem may be fixed but at the same time if there are differences then I may damage the power board of the unlocked BeCM.
Any ideas on how to proceed?
1998 4.6 HSE
130,000 KM (80,000 Miles)
User avatar
jchabol
Postby shupack » Fri Jun 25, 2010 6:27 pm
"unlocked" means you can put it in and go, programming is nice, but not a necessity.
-Dennis
'95 4.0 "Darcy"
User avatar
shupack
Vendor
Next
Return to Range Rover P38A Forum
Who is online
Users browsing this forum: Three Phase, Yahoo [Bot] and 6 guests
