Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews
Classic Sump Plug Size
The technical forum for the original Range Rover 1970-95
Moderators: Tim (Scotland), knudsen, Granny
Postby RED » Tue Oct 30, 2007 10:06 pm
I want to fit my 2 Classics with Fumoto oil drain valves, but I have been unable to find out definitively the size and thread of the sump plug - even tried calling Land Rover in the UK without success!
Anyone know the sump plug specs?Thanks RED[/b]
RED - Kyneton, Australia
Previously
1985 County 3.5
1984 Range Rover 3.5
Current
1986 HiLine 3.9
1991 Vogue+ 4.6
1995 P38 SE 4.0
1944 Willys Jeep
RED
Postby RED » Fri Nov 16, 2007 3:51 am
And the answer is - well I decided to buy a spare sump plug and give it to one of the engineers in our machine shop at work; the response is it is not a standard anything! 20.5mm or ~13/16 and 14TPI BSW thread, in other words, it is an orphan and none of the Fumoto oil drain plugs will fit. However, the engineer did have a good suggestion, drill out the standard sump plug and tap it so that one of the smaller size Fumoto valves can be screwed into the old plug.
Regards
RED
Previously
1985 County 3.5
Current
1986 HiLine 3.9
1991 Vogue+ 4.6
1995 P38 SE 4.0
1944 Willys Jeep
RED
Postby mik100 » Sat Nov 17, 2007 8:24 pm
Hi
I fitted drainvalves from http://shop.difflock.com/range-rover-dr ... -p-42.html to my Classic and P38. They are very well made, and certainly with the Classic save a lot of mess.
Regards
Mik
1988 3.5l Vogue SE
2000 4.6l Vogue
1971 MGB Roadster
1992 Mercedes SL500
mik100
Postby RED » Wed Nov 21, 2007 12:53 pm
Thanks Mik; I have ordered the plugs from the link you provided; will save me a lot of work in drilling and tapping sump plugs!
Regards
RED
Previously
1985 County 3.5
Current
1986 HiLine 3.9
1991 Vogue+ 4.6
1995 P38 SE 4.0
1944 Willys Jeep
RED
Re: Classic Sump Plug Size
Postby CSKfan » Thu Nov 05, 2009 7:43 am
Rover V8 3500 sump plug size is 1/2" BSP, just had a tap through my P6B sump thread to confirm for a chap on the P6ROC forum who is asking the same and looking at these "no mess" drain valves but i also pointed out that the threaded boss which protrudes into the sump has two small holes through the thread to allow the residual oil held back by the protrusion of the boss into the sump to drain out so i'm thinking that these no mess drain valves when fitted will block these holes off and you won't get a complete drain allowing sludge to build up over time?? which you otherwise would not clear unless you dropped the sump. not sure if the new valves would accomodate/compensate for this, just thought I'd let you know. I'm still using the standard sump plug by the way.
p.s. I only have a P6B but would like to have an early 2 door rangie one day...
Regards,
Scott
CSKfan
Postby Danny » Thu Nov 05, 2009 9:44 am
CSKfan wrote:p.s. I only have a P6B but would like to have an early 2 door rangie one day...
Regards,
Scott
I'd like to see some pictures of the Rover - I'd gladly have a P6B.
Danny
'94 RRC V8, 3.9 auto Vogue, LPG.
Estne volumen in toga, an solum tibi libet me videre?
Danny
Postby rufant » Thu Nov 05, 2009 11:51 am
Regards,
Scott
Ditto
rufant
1994 Range Rover LSE
1987 BMW M3
1987 BMW 635CSi
1965 Ford Anglia
2004 Whyte PRST-4
2009 Jamis Dragon 29er
rufant
Solihull Member
Postby CSKfan » Sat Nov 07, 2009 7:17 am
my pleasure Danny/rufant,
My 1974 P6B 3500; (you guys use the same web format as the P6ROC forum)
and the sump plug threaded boss on the inside of tht sump pan;
As sombody pointed out on the P6ROC forum, to make effective use of the "no mess" type drain valves it would be an idea to have another boss made up and braze this on the other side of the pan on the outside so you have a smooth inner surface to fully drain all the oil.
Regards,
Scott
CSKfan
Postby rufant » Sat Nov 07, 2009 3:19 pm
Very cool. Thanks.
rufant
1987 BMW M3
1987 BMW 635CSi
1965 Ford Anglia
2004 Whyte PRST-4
rufant
Solihull Member
Return to Range Rover Classic Forum
Who is online
Users browsing this forum: TerryG and 0 guests
cron
