If your like me you cant stand seeing your bike being rained on, much less stolen. So heres the answer.
Go to your local hardware store, not Home Depot or Lowes, and buy a white paint marker and a 2x4.
Go to your bike shop and buy a fork mount, should run you $20
Now get your helper and a drill, Sharpie, tape measure, drill bits, saw, and two screws to mount the fork mount.
First step is to cut the board to 41in, put a mark 20.5in in the middle of the board. Mount the fork mout in the center of the board using your mark. Now you just flip up your back seats and set the rack in. No bolting required.
Now take the paint marker and mark on your seatpost where you like it and then let it all the way down. Now your saddle wont tear your headlinner.
So heres before
And after
You can also lock your bike in for more protection
Hope you enjoy
93' RRC LWB: water tank, 35gal fuel tank, winch, CB/2m/70cm/VHF, dual batteries, 3.5in lift, IC-9100 UF/UHF coming soon
