| Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews |
Moderators: umbertob, marcpablo
I will keep the forum posted when they do, should anyone else be suffering from this same noise (which also occurs on Disco/LR3s.)Id 42706
Models
LA - Discovery 3
LS - Range Rover Sport
Title LR3 / Range Rover Sport HVAC Squeak / Squeal in Recirc mode
Last Modified 10-NOV-2009 12:12
Category Electrical
Symptom 208000 Climate Control
Content
Concern
LR3 and Range Rover Sport customers may report that a squeak / squeal noise is heard a few seconds after pressing the recirculation button on the Climate control panel, it can be also heard when the recirculation feature operates automatically as previously described in TSB LTB 00103v2
Action
TSB LTB 00103v2 has now been withdrawn from GTR and is no longer an approved fix for this warranty claim. With this in mind we kindly request that Dealers immediately refrain from carrying out the replacement of the HVAC Actuator Rod and the Recirculation Blend Door Actuator.
A new TSB will be released very shortly which requires the application of a new special grease to the affected area, this will reduce the repair time greatly. There will be no need to remove fascia in the new repair procedure.
acole10000 wrote:Blend Door Motor....Just had mine changed under warranty, Out of warranty if costs about $64,950 to replace (that includes twenty inch rims)......
umbertob wrote:A new TSB will be released very shortly which requires the application of a new special grease
umbertob wrote:Ah of course, that's more down my alley. Isn't the car going to smell like a pizzeria whenever recirculation kicks in, though?
Return to Range Rover Sport Forum
Users browsing this forum: Google Adsense [Bot], RRS10 and 2 guests
