| Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews |
Moderators: umbertob, marcpablo
chronoguy wrote:I just had this done on my truck.
phil. wrote:i just called to ask about this and was told a new bulletin was issued last week. he mentioned one bulletin was per customer request (presumably the one umberto posted to start this thread) and another one for customer complaint issues. some of the complaints i wrote down were phone works then no recognized, locks up when calling, signal lost, etc. my guess is this would do the same upgrade, but the more recent one states it may be covered under warranty for approved phones. any info on this?
TOOLS:
Latest IDS DVD; software first released on DVD 111 Patch File 6
Midtronics PSC-550 Vehicle Power Supply
INSTALLATION PROCEDURE
RECONFIGURE THE CELLULAR TELEPHONE CONTROL MODULE
CAUTION: A Midtronics PSC-550 Vehicle Power Supply must be connected to the vehicle battery during diagnosis.
1. Connect the Midtronics PSC-550 power supply to the vehicle battery.
NOTE: IDS must be loaded with software release DVD 111 with Patch File 6 or later.
2. Connect the IDS to the vehicle and begin a new diagnostic session by entering the correct VIN for the current vehicle.
3. Follow the IDS prompts to read the vehicle configuration.
4. Select 'No' when prompted 'Do you wish to read diagnostic trouble codes?'
5. Select 'tick' to continue.
6. Select the 'Vehicle Configuration' tab when Content Model is displayed.
7. From the Vehicle Configuration menu, configure the 'Cellular telephone control module' by selecting from the drop-down menu:
• 'Module programming' > 'Configure existing module' > 'Cellular telephone control module'
8. Select 'tick' to continue.
9. When the 'TEL_SYSTEM_A module' Network integrity test results file displays, locate '0xf191vm_ecu_hw_pn' and record the "value" on the repair order. (Figure 1)
10. Select the value recorded on the repair order when the pop-up screen appears. (Figure 2)
11. Select 'Active' when prompted 'Is phone voice control active?'
12. Press 'tick' to continue.
13. Select 'Yes' when prompted 'Do you wish to install phonebook over bluetooth upgrade?'.
14. Press 'tick' to continue.
15. Select 'US English' when prompted 'Select language'.
16. Press 'tick' to continue.
17. Select appropriate hardware type (noted in step 9) when prompted 'Select the telephone hardware type?'.
18. Press 'tick' to continue.
19. Verify software to be downloaded.
20. Press 'tick' to continue.
21. When completed, exit the current session.
22. Disconnect the IDS and Midtronics PSC-550 Vehicle Battery Supply.
Return to Range Rover Sport Forum
Users browsing this forum: TriRover and 3 guests
