| Direct link to Edmunds.com Land Rover/Range Rover Info, RR Sport prices, quotes, reviews |
Moderators: umbertob, marcpablo
Lee_D wrote:If you have the same model as me then try the following
Will low box select?
Have you checked the fuse has not been left in socket 37? If it is there pull it out. Normal service will resume.
It seems real odd but thats the way it has been designed and actually features in the owners manual but who ever reads them!
Dan_UK_1984 wrote:It may have thought the suspension was in off road mode, mine does that if parked at a funny angle on the drive sometimes. Don't worry about it.
Dan_UK_1984 wrote:How fast were you going!?
maverixz wrote:Dan_UK_1984 wrote:How fast were you going!?
I'd safely presume normal backup speed...... barely 5 mph.
Dan_UK_1984 wrote:maverixz wrote:Dan_UK_1984 wrote:How fast were you going!?
Well that's not going to break any speed records! I'm sure I've reversed faster than that.
Gazellio wrote:What Model year is Blue Puma?
Dan_UK_1984 wrote:Random error messages often means a failing battery. Have you checked the voltages? Even with the engine running it seems if the battery is on its way out some of the systems will behave strangely.
There is an electrical sticky at the top of the thread, give it a read and go from there.
Dan
Return to Range Rover MKIII Forum
Users browsing this forum: No registered users and 10 guests
